Home > General (L494) > ACC – "Radar blocked" |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
More and more regularly when using the ACC I'm getting a "radar blocked" warning and the system disengages, followed by a second, much longer note on the dash which says something along lines of "IEB system deactivated..." Everything usually re-engages within a few minutes (no need to restart ignition) and, from memory, more often happens in bad weather. Sometimes also prevents engaging system in the first place but, again, usually changes its mind after a few minutes.
Thu Jan 25 2018 12:33pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
The radar is the flat black plate beneath the number plate. Check it is not blocked just in case! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Thu Jan 25 2018 2:55pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Had this issue the other day when driving in a snow shower, the sensor is located I the front under the grill,, didn't take much snow to cover it, once blocked forward alert and camera's no longer function 2010 RRS, TDV8
Thu Jan 25 2018 6:49pm |
This has been a problem with DiscoSports and Evoques with ACC and the smart braking system and there was found to be a fault with the camera linked to the IEB system - check that it isn’t dirty but also you may have to visit a service bay for warranty work. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jan 25 2018 6:52pm |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 |
IEB is radar. AEB is camera. RRS MY17 SDV6 AB
Thu Jan 25 2018 10:31pm |
