Home > Maintenance & Modifications > Windscreen washer jets
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Hi all,
Haven’t seen anything posted for a while on this.
Recently my windscreen washers stopped working. Just as we are getting regular snow, sleet and rain.
The headlamp washers and read screen washers both work.
I can hear the motor whirring when pressing the button on the stalk.
Am i to presume that it could be down to the tubing (2006 car) potentially being at fault.
To check this would require taking the bonnet muffler off. ??
Any tricky moments ahead that anyone knows of with taking the muffler matt off and not replacing it immediately?
Are the washer pipes easy to locate/ replace?
Cheers 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #542540 Sun Dec 03 2017 2:20pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
The under bonnet sound deadening pad is fairly easy to remove which I did recently to install Dynamat sound proofing. I suggest you use a V notch plastic trim removal device to extract the Christmas tree clips. The pad needs to be fully supported as you remove the last few clips as it is likely to bend in half if you don't and damage the material. Two people job.
There is no problem in driving around without the pad in place.
Pictures of the windcsreen nozzles from under the bonnet.
Post #543230 Tue Dec 12 2017 4:52am
Pakolainen
Just had the brake discs snd pads chsnged. Then in for a mot. After that washer jets suddenly working. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #546740 Thu Jan 25 2018 5:10pm
geoffsnook
I will watch this thread as my passenger side one does not work very well Thumbs Up
Post #546744 Thu Jan 25 2018 6:23pm
