![]() | Home > General > Battery low |
If you get a dash load of warnings on L320 RRS1 then also check that a tail light isn’t out - one lamp out at the back can also cause a shed load of apparrant issues. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
The first question to asking yourself is why was the battery low so low? Do you have a parasitic drain somewhere or is the battery old / tired. Perhaps the alternator is getting tired. Be worth keeping a check on the state of charge to see if you can fix it before it dies on you. 2012 SDV6 - it's missing a couple of cylinders
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
To be honest I think it's down to very little use , short town journeys , winter conditions and having things on like front heated window to defrost, heated seats first thing in a morning etc , battery fully charged and everything back to normal , but you are right in pointing out that I could have a potential underlying problem and I will keep a close eye on charge 👍Ps battery is just over 2 years old |
Kaywood Member Since: 01 Feb 2018 Location: Yorkshire Posts: 6 ![]() ![]() |
is the L320 ok to trickle charge, whilst bty is situ & connected?
