Home > Faults & Fixes > another air susspension problem
Pauly14666
Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Hello would like to see if anyone could help me with my jeep iv been getting a yellow warning light on the dash after an hour of driving resets after ignition is tired of and back on I can hear the compressor Turing on and off when I'm stopped in traffic and when I start it in the moring it's comes on i have fault codes
C1A37
C1A13
C112F
C1130
Any help would be great thanks
Post #546216 Thu Jan 18 2018 8:53pm
The codes are incomplete but:
C1A37 - front cross link valve issue
C1A13 - exhaust valve problem as the system isn't dumping pressure when required
C112F - corner valve stuck
C1130 - air spring air supply - could point to a leak, a blocked pipe or a corner/exhaust valve stuck 2012 SDV6 - it's missing a couple of cylinders
Post #546228 Fri Jan 19 2018 12:07am
Pauly14666
Thanks for the reply any idea on how to fix this or what parts I will need to sort the problem thanks
Post #546232 Fri Jan 19 2018 12:32am
