![]() | Home > Faults & Fixes > HELP: RRS 2011 Auto loss of power |
You need to have the codes read first so we know what we are looking at could be a gearbox fault could be a bad bulb there are so many things it could be so if you can get the codes it would be useful |
jig Member Since: 14 Jan 2018 Location: London Posts: 40 ![]() ![]() |
Thanks Geoff. Is there a cable and software that everyone use to read the codes? |
Check out the Sponsors on here and the Disco 4 forum http://www.disco4.com/forum/sponsors.php
Most use a IID tool approx £400 but well worth it but as said geoff. is down your way who may be able to help |
Thanks all. £400 is a lot. Will have to get a specialist to do a diagnostic and give me a price. Any likely culprits? The problem isn't consist and there are no sounds from the gearbox |
As said maybe speak or pm to geoff. that is his user name i think he is not to far from you and does have a lot of knowledge ans expertise with land rovers |
You will need 5 post's first though then just go to the PMs and search for geoff. type it in just like that |
Thanks guys |
Where is Geoff based anyone know? |
West kent go into pms and search for him you can do it now but search geoff. all in lower case and a full stop at the end |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Yes, I believe he’s Edenbridge way Robin
