![]() | Home > Wheels & Tyres > Tyre inflation. |
How many miles have you done with low tyre pressures as that may have reduced the tyre’s life by a couple of thousand miles...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I know, it`s shocking.... |
Now that's bad luck. I check mine every couple of weeks, probably more habit not much to be gained but a lot to loose - premature tyre wear/fuel consumption etc.... |
Steve you need to find one with the optional TPMS which is now a legal requirement on post 2014 cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
You can buy good After market TPMS . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
This company do good systems,but you would have to find somewhere to fit the screen.
I usually do check tyres regularly ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I fitted one of those systems to my pre-face lift RRS1. Fitted the screen in the centre of the black plastic bezel in front of the instrument cluster virtually touching the clear plastic front of the instrument panel, although not perfect thought it blended in quite well and did not obscure anything and could be quite easily seen from drivers seat. The system it's self worked very well, only thing being the dust cap sensors are quite large and conspicuous. Current RRS1 has factory TPMS fitted, £400.00 option and it is totally useless, all it does is tell you have a under inflated tyre if the pressure drops below 25psi. at what ever wheel that's it. Cheers Col |
I just need to get back in the habit of regular checking.....or, whack some nitrogen in, good for around 6 months then |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Why is nitrogen so good at not leaking? Or is it one of those marketing gimmicks to get people to spend money on having their tyres inflated at a tyre place?
I don`t know the science behind it (I know it`s used in racing and aircraft) but I do know it doesn`t lose pressure like air. I`ve used it in the past, many times and it lasts around 6 months before it starts to drop any pressure. I think it might be because the nitrogen molecules are larger than the oxygen they’ve replaced.
Oh and I do have these but they`re no good if I don`t use them ![]() ![]() |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I should get one of those devices Tyrefitter - I am the world's worst at checking pressures regularly |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Depends on the trailer noseweight more than trailer load. From memory my IFW 3.5t has an empty noseweight of around 75kg, and I try to keep it between that and 100kg (I don't worry too much for mostly short runs that I do). So even with 100kg on the ball then I doubt it'd need much increase, or maybe just a few psi. If using the fixed towbar then it might be higher rated, but I've not yet seen a trailer hitch with more than 150kg limit (they may well exist, just I've never seen one in the UK) 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
