Home > General > Engine in but still problem
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Morning all
Rebuilt engine back in my 2.7 sport
But lots of warning lights h d c transmission
Hand brake etc
Started engine for first time
Fired into life perfect then all faults
Showing standing in front of car and saw just a small
Whisper of smoke coming from back of engine
Top of bulkhead Where wireing harness meet and drop down to
Gearbox knowing my luck it will be gearbox harness
Took battrey back off just in case
My question is can I remove gearbox harness
Without takeing gearbox out
Thank you for any help or advise in advance
Post #545608 Fri Jan 12 2018 7:12am
Go on eBay and buy a copy of the workshop manual for a tenner. A lot better than posting and waiting for answers on here. Thumbs Up
There aren't many mechanics on here so you could wait a while for an answer. 2012 SDV6 - it's missing a couple of cylinders
Post #545620 Fri Jan 12 2018 9:47am
Bullnogger
Thanks for reply appreciated
Got Haynes manual doesn't tell you
What I need to no
Ah well out she comes another
Weekend under it
Post #545628 Fri Jan 12 2018 10:26am
Tim in Scotland
First I am not a mechanic and prefer to pay other more competent people to look after my cars but through long term membership of the forum and having read posts of electronic problems your problem might be because you might have disconnected all the electronics from the engine and the ECU no longer recognises the engine and might need to be reconnected to a diagnostic machine to reset everything. I’m sure that somebody like Mikey/Bodsy will be along and tell me I am talking nonsense but i’m Pretty certain that when major components of modern Land Rover products are disconnected from their ECU’s there can be problems when you reconnect them with them not recognising each other. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #545631 Fri Jan 12 2018 11:06am
can't see why you wouldn't be able to remove the harness.
check everything is plugged in behind the battery ( there are 2 large flying connectors)
check where the smoke same from to see if short to metal work.
you could glance over the large fuses by the battery
it could be just oil burning off ?
Post #545637 Fri Jan 12 2018 11:52am
Bullnogger
Thank you for your replies
Really appreciate it good points
Going to check all electrical connections
Over weekend hopefully something simple
Like I say removed transfer box gearbox
Engine had a rebuild put all back in engine
Running (thanks Andy for advise )
But now got problems with electrical
Faults once again thank you
Post #545658 Fri Jan 12 2018 3:38pm
What I need to no
Weekend under it
The workshop manual is 5000+ pages. The Haynes manual can't compete...
If you're as hands-on as you obviously are, for a tenner it's a no-brainer, surely. 2012 SDV6 - it's missing a couple of cylinders
Post #545667 Fri Jan 12 2018 5:08pm
Bullnogger
Didn't realise that thank you for the
Info I will certainly be getting hold of that
never to old to learn brilliant Haynes in the bin !!!!
Post #545684 Fri Jan 12 2018 9:05pm
