Home > Technical > interior upgrade
alanm85
Scotland 2007 Range Rover Sport TDV6 Autobiography Zermatt Silver
interior upgrade
i have a 2007 rrs. the interior has been changed to the newer model using the seats, door panels, steering wheel and stalks.
few problems im having is the intermittent wipers dont work. i found if i unplug the rain sensor they start working but then the auto lights dont work. plug it back in the light sensor works but the intermittent wipers stop
other is the heated seats dont work. i think there seems to be a wiring difference.
any help on these issues would be greatly appreciated
Post #545576 Thu Jan 11 2018 10:45pm
qcnr
Norway 2007 Range Rover Sport TDV6 HSE Lux Buckingham Blue
I'm not sure this will help. Min has auto wipers and i find it the most annoying irritating and off Censored feature
to ever have been installed on a car. There is a switch which I use to set the speed of the wipers that suits me.
But the auto wipers obviosly know much better than I do as to how I need the windscreen cleaning.
It is especially annoying when relatively dry but damp salted roads. The wipers will wipe but not enough
moisture on the road so smear the windscreen.
Are you sure they don't work, do you mean the wipers won't wipe at all when you switch them on?
Post #545605 Fri Jan 12 2018 7:12am
alanm85
yes i know what you mean. im not fussed about the auto wipers working off the rain sensor but more just having the intermittent feature with the speed setting working.
just now i have push it down to clear the window. its abit annoying having to do this constantly when its light rain and not heavy enough to leave them on the constant setting
Post #545617 Fri Jan 12 2018 9:56am
You can disable the auto wipers feature using an IID or similar. Just change the CCF so it shows no auto wipers and then the intermittent switch works as you would expect. That's what I did on my TDV8. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #545622 Fri Jan 12 2018 10:50am
alanm85
will give that a try. wasnt sure it the wiring may have been different
Post #545624 Fri Jan 12 2018 10:51am
the light sensor and rain sensor are in the same unit
You don't have intermittant when the rain sensor is working, as the rain sensor does it for you
Post #545638 Fri Jan 12 2018 12:57pm
alanm85
yeah thats right.
the wipers dont come on when it rains. i know the sensor is working as i tried it in another range rover and it worked when i sprayed water on the widscreen
Post #545640 Fri Jan 12 2018 1:00pm
Cymruambyth
Wales
I agree...pointless feature. Either it goes full pelt when it`s barely drizzling or hardly works when it`s bouncing down. Steve.
Post #545648 Fri Jan 12 2018 1:59pm
alanm85
agreed. id be happy to just get the intermittent setting to work and just adjust the speed myself
Post #545649 Fri Jan 12 2018 2:01pm
Mine work great
May depend if its been glued on correctly
Post #545659 Fri Jan 12 2018 4:40pm
Eaters
I love my auto wipe. Works well for me Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #545676 Fri Jan 12 2018 7:40pm
