Home > General > Buying a RRS and lack of EML
sick2death
Hi folks. New member, signed up as Im currently in the market for a (used) RRS. I've looked at 2 so far, and ended up walking away from both. Amongst other reasons, neither of these had an EML check on startup.
The first was an 06 model. After not seeing an EML on startup, I checked the manual to see where the EML is located on the dash to confirm it wasn't lighting on ignition. Which it wasnt.
The second was also 06. On startup, I again noticed no EML. I remembered from the first where the EML should be, but where I thought it was, instead was the glow plug light. So I'm thinking I may be looking at this the wrong way.
I'm going to look at a 55 next weekend, and would appreciate if someone could clear up for me, ideally with a pic where the EML should be, if it should be illuminated at startup, or if indeed there is one!
Many thanks.
Post #545080 Sun Jan 07 2018 6:29pm
geoffsnook
Have a look here there should be a light that comes on and then goes out if the check does not find any issues Thumbs Up
http://www.diagnostic-world.com/pages/rang...226508.cfm
Post #545111 Sun Jan 07 2018 8:04pm
Those early ones don't have um.
If there is a fault you get a bong and message on display
Post #545112 Sun Jan 07 2018 8:06pm
sick2death
Thanks for the replies. Was a biut confusing, especially as the manual seemed to suggest the an EML was present!
Post #545118 Sun Jan 07 2018 8:18pm
geoffsnook
No i stand corrected it my say that but just checked my 05 Supercharged and as Andy says no eml Thumbs Up
Post #545121 Sun Jan 07 2018 8:25pm
