Home > General > Pre purchase brain picking please.
Page 1 of 5 12345>
Sportie
Hi all,
I have decided to buy a RRS later this year; it will be my first. Looking to spend circa £12k. I know there will be differences of opinion but any advice on what to go for would be great.
It will be our only car (unless it gets too painful), I have a leased 48MPG Diesel modern car at the moment. I do have a motorcycle for decent weather commuting (too old to do the winters any more).
The plan is for a £12k spend in April/May. Car to have under 100k miles, as much service history as possible, warranty if possible. As well as the spend I intend to have a penny jar for repairs of a couple of grand and a few £hundred added to the jar each month (insurance, tax and fuel paid for separately). I intend to get it serviced at/soon after purchase with a new battery. I am in Loughborough and there seem to be a couple of reasonable indie servicing places locally.
I travel 10k miles per year and don't expect to get many miles to the gallon. I am looking for reliability/spec mix.
If you would give me some pointers as to what model I should be looking for please, I would be grateful.
Thanks.
Post #545076 Sun Jan 07 2018 6:23pm
geoffsnook
TDV8 is maybe your best bet does not snap cranks but has some issues with turbo's split manifolds but maybe less expensive than if the crank goes on a TDV6 or a supercharged which does between 9 and 18 mpg depends on what you want and what you can get at the time you purchase but below 100.000 will be one of the hard part's Thumbs Up
Post #545086 Sun Jan 07 2018 6:51pm
geoffsnook
There's one on the forum have a look to see looks nice Thumbs Up
Post #545089 Sun Jan 07 2018 6:55pm
geoffsnook
http://www.rrsport.co.uk/forum/topic49667.html Thumbs Up
Post #545090 Sun Jan 07 2018 6:56pm
Sportie
Thanks for the reply Thumbs Up . The one for sale does look great but I am not looking to buy until April due to the balance of my existing car lease meaning that I would have to still pay for the lease car while it sat on my drive.
Thanks for the suggestions. TDV8 does sound good and I could also live with an average 18MPG - not sure about the single figure MPG though!
All thoughts welcome. Cheers.
Post #545097 Sun Jan 07 2018 7:17pm
geoffsnook
TDV8 will do more than that but my supercharged wont lucky to get 18 usually closer to 11-12 as the sound and the power are awesome Rolling with laughter
Post #545099 Sun Jan 07 2018 7:20pm
Sportie
Quote:
the sound and the power are awesome...
That is just teasing Bow down
Post #545101 Sun Jan 07 2018 7:28pm
riverblanche
Hi and welcome Thumbs Up
Take your time read up on here and D3 go and see Now, as many as are local to you, you will start to spot Bad ones Rolling Eyes And maybe spot a good one or two Question
It's easy to drop £2k on some preventative, catch up, maintenance
Don't think you will get into a Good 3.0tdv6 (2010) so either last of the 2.7tdv6 or an early 2.7tdv6
Buy one with Good Recent history rather than one with good early history and nowt done for last few years, maybe time for spending on it again?
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #545102 Sun Jan 07 2018 7:37pm
geoffsnook
|If you can find a well looked after TDV8 you should go for that i had the TDV6 and even with a remap up to 235 bhp it still felt under powered a bit but at 270 bhp in the TDV8 they are well worth it and they dont snap cranks unlike the TDV6 but have a few problems of there own but all these problems are not happening every day so dont be put off Thumbs Up
Post #545105 Sun Jan 07 2018 7:44pm
riverblanche
Try both and see what you think Thumbs Up
Cranks on Sdv6 not so much Tdv6 ? Cooked turbos on tdv8 and there not cheap either
does not seem to be a problem on FFRR more so on RRS tighter engine bay?
But they ALL want maintenance and you never know what's on the horizon
Try a few, take a punt and enjoy Thumbs Up Porsche Cayenne 2022
Post #545110 Sun Jan 07 2018 8:02pm
geoffsnook
Don't really think you will get a SDV6 at 10K may need a bit more dosh as i was once told the V6 is just a V8 with 2 cylinders cut off as the owners did not want to pay the bill for designing a new engine and hence some of the problems but may have been told porkies Whistle Whistle
Post #545113 Sun Jan 07 2018 8:10pm
d-9
Tdv8 is fantastic,I test drove a tdv6 and was very underwhelmed - turns out the 0-60 is about 12s! The tdv8 feels like the right motor for the car (unless you can afford 12mpg). I get between 21 and 31mpg from my tdv8 depending on the sort of driving, running around its usually about 22/23 and on a run its 26/27, 31 is the best I've had, lots of motorway at 50mph.
Reliability is all about maintenance and how it's used. I'd rather take a 120k car that has sat on the motorway than a 50k car that's done 4 miles to and from school, twice a day.
Post #545140 Sun Jan 07 2018 11:15pm
Indeed so. The V8 is a 90 degree block (60deg for the V6) so the turbos are mounted lower than would be ideal because of a lack of space. LR use a pump to pump oil away from the turbos. Seems that if the turbos aren't allowed to cool with the engine idling for a minute or two, the oil burns and eventually blocks the pipework. This causes the oil seal in the turbo to fail. Regular oil changes using good oil and allowing the turbos to cool and spin down seems to be key to long turbo life. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #545156 Mon Jan 08 2018 9:25am
Sportie
Thanks everyone for replying. As much as the Tinterweb can be dodgy, there are some fantastic uses for it and being able to pick peoples brains and listen to their experience are just a couple of those fantastic uses. Thank you and some comments based on your comments:
..It's easy to drop £2k on some preventative, catch up, maintenance
Buy one with Good Recent history rather than one with good early history and nowt done for last few years, maybe time for spending on it again? Thumbs Up
Thanks for this. The plan was to get a decent Rolling Eyes one and spend a few quid on a good service and battery. I get the comment about the recent service and intend to check the MOT history online.
A V8 sounds good, the last V8 I had was a SD1 Embarassed
riverblanche wrote:
……..Cranks on Sdv6 not so much Tdv6 ? Cooked turbos on tdv8 and there not cheap either does not seem to be a problem on FFRR more so on RRS tighter engine bay?
But they ALL want maintenance and you never know what's on the horizon……..
Note to self – check the difference between a SDV and TDV. I don’t really want a FF so that option is out.
As for never knowing what is on the horizon, I have a Grand C4 lease car. It has been in the dealers about a dozen times. The only difference is I didn’t have to pay the bills Laughing I do own a Ducati so I am regularly worried
I would expect £10k to be a lucky find. I can push the budget a few grand more but would like a few grand left in the penny jar (just in case), and would expect to spend £1k to £1.5k on a good service, battery and possibly a couple of tyres.
It is starting to look like a V8 of some description.
Thank you all again.
Post #545158 Mon Jan 08 2018 9:30am
Sportie
Interesting. When turbo cars first came out for the common man - I am talking Renault 5 turbos etc, I thought that you always had to idle to car to get the turbo down in colour from cherry pink. A good reminder for me though. Thanks.
Post #545159 Mon Jan 08 2018 9:32am
Page 1 of 5 12345>
