Home > Technical > Steering wheel controls and air bag light
Wynne1991
Wales 2005 Range Rover Sport TDV6 HSE Siberian Silver
2005 sport my steering wheel controls don't work , the illumination does light but will flick on and off and the air bag light is on ! Any help please
Post #544924 Fri Jan 05 2018 10:03pm
GodivaNige
Could be a faulty clock spring but it’s worth trying a new steering wheel loom first, much cheaper and very easy to do.
https://www.ebay.co.uk/p/Land-Rover-Discov.../650668046
You’ll need to remove the airbag, carefully, after disconnecting the battery and waiting 20 minutes. To remove the airbag a tool is needed or you can try bending a wire coat hanger.
https://www.ebay.co.uk/itm/Steering-Wheel-...SwyZ5Ulp3r
There’s a video on you tube which shows how to do it Thumbs Up
Post #544929 Fri Jan 05 2018 10:52pm
Wynne1991
Ok thanks
Post #544940 Sat Jan 06 2018 8:55am
Scrumpy
When you say the airbag light is on, do you mean on the instrument display or on the centre console above the stereo?
If it's above the stereo it just means that the passenger airbag has been deactivated (usually if there was a child seat in the front).
It can be reactivated by opening the passenger door and using your key to activate it just below the front A plllar.
Not sure if that's what you're referring to so sorry if it's not! 2016 RRS SVR Estoril Blue
Post #544956 Sat Jan 06 2018 3:08pm
geoffsnook
Loads of problems with the small loom behind the air bag for the buttons try this first as you can pick up the loom cheaply that is what it was on mine:thumbsup:
Post #544965 Sat Jan 06 2018 4:54pm
GodivaNige
And mine, my radio controls were still doing weird things even after changing the radio. New loom cured it.
Post #544967 Sat Jan 06 2018 5:24pm
