![]() | Home > General > What to do ? |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
My take is use the Indie if you know them as LR specialists.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
I only use indy specialist now, and not for price reasons. They seem to know what they’re doing. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
I would not even entertain the main dealer, its a decent indie all day long. They want your business, plus just because its a recon doesn't mean a lot just get that reassurance from them that's its a good supplier |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 ![]() ![]() ![]() |
spending £3000 on a 9 year old car without good reason (i.e engine) doesn't sound like a good idea if you can avoid it. |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
One of the problems is actually getting someone to say it is definitely a torque converter that is causing the shudder , both Indy and stealers hav'nt committed to saying that is the cause ! I'm going off what other people on here have experienced and what they have done to solve the shudder ! As a cheap and quick solution I'm tempted to use "Dr Tranny / lube guard " as someone mentioned it was very good at stopping the shudder but is this just postponing the inevitable TC replacement! I agree that £3000 is a huge amount of money to throw at a 9 year old car but I imagine I will still have this car in 5 years time or longer and the original TC it was fitted with lasted 100.000 miles . I'm not sure which way to go with this but I know it needs sorting . Thanks for all opinions |
I see your predicament and have been there myself.
Yes it is a predicament , I rang my local stealers yesterday to see if they would be able to take car out for a test drive with me as ideally I need a postitive diagnosis . They were supposed to have rang me back but they never did so I’m a little peed off with them ! Currently I’ve asked a good friend ( who is a motor mechanic) if he’d help putting the “drtranny “into gearbox to see if this improves the shudder! This is next week so hopefully I’ll get that done and give it a while before deciding what to do ! I’m going over to the continent in June on a long treck and want it sorted before then !! To be honest the £3000 is painful but if this is going to sort it I see it as necessary, I may approach another local stealer yet for their opinion! |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Have you seen this over on the disco3 https://disco3.co.uk/forum/tc-quote-167286.html
Thanks David that is very interesting. As you say the only problem is distance from me ( Peterborough) but. Massive saving. Would be keen to hear from anyone who has used these people |
It's also interesting to read on that link that it's pointed out that "Dr Tranny " instant cure is not the best approach to this problem and I'm pleased that you have found this David . I will be giving Them a call for sure . I would recommend anyone with a TC problem to read the link as it's also pointed out that replacing input shaft bearings and seals are vital to this fix |
Alfie
millsy123 Member Since: 02 Dec 2017 Location: bham Posts: 4 ![]() ![]() |
i had this shuddering i added some thing called shudder fix which i bought off ebay for twelve pounds ..its just additive and i put it inthru side of trany ..you have to have motor running and in reverse to get room in box for this i think 10cc of fluid ..fixed immediately ..its all over usa forum my shuddering was only really noticable on slight inclines where you hold steady throttle..now gone ....ok ive checked it out its called doctor trannys shudder fix...i didnt believe it either for 3000 quid hey it worked for me good luck |
you shouldn't need to have it in reverse. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
The judder is caused by a deterioration of the clutch material. The additives just mask the issue, they don't solve the problem. The solution is a new TC, especially if one wants to keep the vehicle for a length of time.
