Home > General (L494) > Cannot open reardoor from the outside
Craig Lincs
United Kingdom 2006 Range Rover Sport TDV6 HSE Orkney Grey
Good evening, I am having trouble getting into my 06 rrs. I have taken the door card off but can not see anything obvious from looking thtough the small access holes in the door. I've thought about securing the window and then taking the module out for access. Any tips.? Is it the handle / cable or the latch itself. Any help is appreciated thanks
Post #544460 Sun Dec 31 2017 4:38pm
SRE
Spain
Use the search function, it's well documented.
e.g. http://www.rrsport.co.uk/forum/topic45683....=door+lock In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #544505 Mon Jan 01 2018 1:29pm
Craig Lincs
Thanks for the reply. My door still opens no problem from the inside so doesn't sound like the same fault. I did search for over an hour for the same problem but couldnt find it.
Post #544506 Mon Jan 01 2018 1:36pm
SRE
Spain
Looks like the actuator is on the way out, anyway have a look at this.
https://www.disco3.co.uk/wiki/Rear_Door_Latch_Replacement In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #544509 Mon Jan 01 2018 2:10pm
