Home > Faults & Fixes > Fault code c1A00
Wynne1991
Wales 2005 Range Rover Sport TDV6 HSE Siberian Silver
Fault code c1A00
Hi I have fault c1A00 -control module as a permanent fault in the abs system ! No faults on dash just off diagnostics any help
Post #544340 Fri Dec 29 2017 8:42pm
Tyrefitter
It could be a stored code,problem might have been fixed but code not removed at time of fix Thumbs Up
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #544341 Fri Dec 29 2017 8:48pm
Wynne1991
Could be I cleared faults didn't check if it did clear can check tomorrow ,when applying the hand brake it makes a loud sqwelling noise could it be related ?
Post #544342 Fri Dec 29 2017 9:05pm
That code relates to Terrain Response Switchpack.
The terrain response
switchpack has
indicated a
calibration/parameter
memory failure for
embedded systems.
Post #544343 Fri Dec 29 2017 9:06pm
glennp123
United Kingdom 2007 Range Rover Sport TDV8 HSE Firenze Red
sounds to me like your handbrake control module isn't working! if it makes a loud screech noise im afraid. That fault code is the same one a diagnostics machine gave me when my handbrake wasn't working, but it turned out in my case it was broken wires going to the switch... however your symptoms point towards the module itself with the loud noise.
Post #545038 Sun Jan 07 2018 1:16pm
