![]() | Home > General > Great timing |
Turn off the ignition, wait 5 minutes and restart........... i’ve Just had the “ Oil level sensor not communicating” warning come up,on my L494 - there is no dipstick so had to pull over switch off and see what happened - on restart, no alarms, continue journey to destination without incident or repetition of the alarm 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
I did 3 restarts with no change. Unpacked into wife's Nissan and started off again. Will see what it's like when we get back home later in the week. Merc C220 estate Sport AMG
I bet it’s something simple |
Had this getting off the Eurotunnel once at the start off a ski trip, plugged in iiD tool and reset codes and was fine for the rest of the trip |
Tried it again yesterday evening, still the same.
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
You will be fine. Just have to do the normal things like set the clock and radio |
Get the codes read so you have some idea of the issue Visitor from fullfatrr.com
Hopefully somewhere will be open tomorrow where I can take it to and get the codes read Merc C220 estate Sport AMG
When did you last have it serviced could be as simple as a blocked fuel filter, good luck with it 2008 G4 RRSport TDV8 current
It had an A service a month ago. Merc C220 estate Sport AMG
Fuel filters not changed on A service so might be worth getting it changed anyhow.. always change mine every year I see quite a few cars with fuel filter issues.. 2008 G4 RRSport TDV8 current
The very nice man from the AA says I need 2 new air mass flow sensors.
