![]() | Home > Maintenance & Modifications > Removing vents |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
Andy,
Mines a RRS2,,don’t want to pull them like that if they are screwed anywhere
If you look at some on the ones on ebay, you can see the retaining tabs and clips. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Andy, I replaced my 2008 with chrome ones. The instructions were to use a sharp upward and outward pull to release them as they are only held in by clips. But I still managed to break a couple of clips on one of mine! Didn’t matter to me as I was replacing them. In your case extra care needed.
RRS2 L494 are a different design and a lot smaller - Andy have you searched YouTube for any PowerfulUK videos? It’s dark outside now so photos done with a Petzel Headlight
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Can't be certain, but can't see any screw fixings I thing the two pegs each end in the top picture are locating lugs, but may be screws from underneath as not sure what is directly under the bonnet vent, looking at Tim's Picture may be another grille screwed in place, but they do look like they are retained by the same style of spring clip that holds most of the dash trim in place as well, the one's that disappear in to oblivion when a piece of trim is pulled off. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
The vent with screw in Tim's photo is the "Queen Mary funnel" vent that feeds the airbox. The side wing and bonnet top "vents" are just plastic trim pieces that serve no purpose other than cheap styling. 2012 SDV6 - it's missing a couple of cylinders
The “Queen Mary” air intakes are also why L494 cannot be fitted with a Raised Air Intake or even a snorkel, the clamshell bonnet and the increased wading depth of L494 is supposed to be sufficient that the car would float anyway if you went in any deeper.......... and i’m Not volunteering to test it to see if it is enough...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Not sure I would describe it as cheap styling Wayne, expensive bit's of plastic at around £800.00 for four pieces at L/R prices. ![]() Cheers Col |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Have you seen this yet - I looked on topix & it recommended fitting new clips |
Thanks guys for all the reply’s,I may see if I can get a pair off eBay & paint them first like Col says.
![]() ![]() ![]() How about "tacky"? ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
