Home > General > Special programs |
Use both but more time and space for braking will always be better as 2.5 toms is quite hard to stop on snow |
Mon Dec 18 2017 9:06am |
Just remember that the special programs are meant to get you going and keep you moving............ they don’t have any effect on stopping distance although HDC can help by stopping wheels from locking up with out you needing to use the foot brake. Also if you get into deep snow and find you need to try using the tyre sidewalls to help get grip by turning the steering a lot then you also need to disable the DSC until you get going again when you should reset it to the default on position. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Dec 18 2017 9:14am |
mattdonut Member Since: 04 Sep 2017 Location: midlands Posts: 11 |
cheers for the replies |
Mon Dec 18 2017 6:05pm |
