![]() | Home > In Car Electronics > Dashcam Hard-wire Install via Overhead Lighting Console? |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Just purchased a Thinkware F770 Dashcam with rear cam add-on and I am looking how to hard-wire it into my 2013 L320.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5045 ![]() ![]() ![]() |
I looked at both ways of hard-wiring it in, and found via the fuse box made a much more "professional" looking job, just piggy-backed off fuses 48 permanent live and 52 aux.feed. Did Rear Cam as you suggested bit fiddly but not to difficult.
Thanks Col for the advice and photos |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
That rear camera job looks very good. I struggle to get my cable through the rubber conduit between the tailgate and the headlining. Might have to give it another go.
I threaded a piece of thin electrical wire through first, then attached it to the camera lead, plenty of silicone lubricant spray then gently pulled it through. Shame the small USB plug is not right angled like the Blackvue one's, would have made slightly neater job with less lead showing.
