Home > Maintenance & Modifications > I'm looking for Chrome Exhaust Tips for my RR Sport TDV6 HSE
Brian will them eBay Tips fit the TDV downpipes ? RRS TDV6 Gone but still around
Post #53955 Fri Sep 08 2006 7:50am
Mazza
2006 Range Rover Sport TDV6 HSE Java Black
Brian Mason wrote:
There's some nice twin tailpipe trims on ebay for £21.99 (£39.98 the pair). They can be properly fitted and welded by your local exhaust specialists (ie Top Gear), or, as previously stated, you can just hacksaw the end of your single pipes and clamp-on the new ones. They do look much better, Im going to have mine done. Good Luck!
They look nice, but as MDP mentioned, the soot will come straight out, which could cause the rear of the car to get covered!
Post #54087 Fri Sep 08 2006 10:07am
They stick out too far
Post #54088 Fri Sep 08 2006 10:07am
Josh
Go for JE, you won't regret it. It looks very good and the sound is def V8 ish.
But I'm damn certain if you choose the cheap option you will soon get fed up cleaning the soot off the back Exclamation Exclamation Exclamation
"You pay for what you get" Exclamation TDV6 - gone
TDV8 - gone
Post #54294 Fri Sep 08 2006 8:06pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
I already have a through-flow stainless steel sports exhaust from Twisted Performance which sounds great and gives no problem with soot flying out: http://www.twistedperformance.co.uk/product_range_rover_sport.htm
However, the two single pipes look a bit lost and lame so it needs quad. I see no reason why they wont fit, but Im going to Top Gear Exhaust specialists (nationwide) who who supply and fit for £100'ish and do a professional job.
Post #54452 Sun Sep 10 2006 3:26am
What's interesting is the quoted performance gains for the system Confused and as for the filter Shocked they are quoting + 10bhp ......... for this. - ITG air filter which is available for all RRS models and is in fact manufactured by ...... JE Engineering! Hmmm 10bhp for the TDV6 ......... and the 4.4 and the Supercharged as well
I think NOT Rolling Eyes
Post #54580 Mon Sep 11 2006 12:21am
Brian Mason
Do you think the figures are "optimistic" then? What do you think it should be?
Post #54925 Tue Sep 12 2006 12:32am
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
I agree with you on the exaggeration of the power gains, but ITG air filters are not manufactured by J.E., they are manufactured by ITG. I've used these filters in the past and have found that, at best, they reduce turbo lag. But 10 bhp? Not on your life. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #54926 Tue Sep 12 2006 5:03am
I'll say it again.................
JE Engineering "OWN" ITG - therefore same thing & the premisses are next to each other.
Also here is a reply from ITG - when I emailed them some time ago for details on their filters ....
QUOTE
"We don’t actually make any claims for increased performance from our panel filters as the gains usually found can be quite small, however most of our customers report that the engine seems to run more freely. Another point raised by customers is that they generally see an extra 1-2 miles per gallon using our filters.
Another advantage with our filters is the way they trap and hold the dirt, paper filters only hold dirt on the surface of the filter, this means that after a short while the airflow will start to decrease quite rapidly. Foam filters on the other hand trap dirt using the depth of the filter and can therefore hold a lot more dirt without losing airflow; this means you will not get the same drop off in performance between services that you would normally find with a paper filter. "
These were the words of :-
Andy Jackson
Parts Manager
Induction Technology Group Ltd
Tel. 02476 305386 Fax. 02476 307999
Hope this clears a few things up - ie 10bhp = I think not !
Ownership = JE
Post #54948 Tue Sep 12 2006 10:46am
