![]() | Home > Maintenance & Modifications > 2007 TDV8 - Suspension Fault |
lkefc84 Member Since: 20 Nov 2017 Location: Burscough Posts: 17 ![]() ![]() ![]() |
Tome Member Since: 20 Mar 2016 Location: West midlands Posts: 21 ![]() ![]() |
I had this our last cold spell, the ARC light come on once, level was fine restarted the car and it went away a month later the alternator was shot and the battery not much better so as paddi said a good charge and a battery/ charging test is the way to go. |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
You got the best engine TDV8
I've had a quick look at the CTEK modern chargers.. would this do the trick? http://www.halfords.com/motoring/bulbs-bla...tsid:94971|cid:865692955|agid:43902123735|tid:pla-332616571812|crid:202397318145|nw:g|rnd:16173686082459686961|dvc:c|adp:1o1|mt:|loc:1006884&gclid=EAIaIQobChMIl6K_kOfo1wIViJPtCh3ypA9rEAQYASABEgKpG_D_BwE I'll try this over the weekend (if suitable) and see what that brings. Failing that, I will seek out a specialist and get the ARC bar brushes checked and changed, if necessary. I thought it may have had something to do with the cold, and the relatively short journeys I do to and from work (12 miles each way). I'll be getting it out for a good cross country run over Christmas, so hopefully that'll help. Thanks for the advice ![]() |
So I am assuming you had top replace the alternator, and battery, and all was good? 2007 TDV8 HSE.. beep beep! |
I've just come from a 2017 Mercedes GLA220d.. the difference is phenomenal! Not very kind on the wallet, but it's more than worth it! I do miss the mod cons (bluetooth, start/stop etc) but not enough to want to go back to a 'normal' car! ![]() |
It would probably do the job but might be a bit slow. The MXS 5.0 charges at a much higher current and gives the RRS battery a full charge in just a few hours. It's the model I use along with many other owners. 2008 MY Java Black TDV8 HSE ![]() |
Ordered |
