Home > Technical > shake under light braking
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
Hello All,
I have a slight (and sometimes not so slight) shake in the steering wheel under LIGHT braking. If i then brake harder the vibration then goes away completely.
Does this sound like a problem with the rotors, or do you think it is a potential problem with a bushing or TR end?
Thanks for your advice!!
Nick
Post #542785 Wed Dec 06 2017 4:51pm
geoffsnook
That sounds like your disc's have warped Thumbs Up
Post #542792 Wed Dec 06 2017 6:21pm
steve.rrs
i had that till last week, front discs warped, new ones fitted, no steering wheel shake now
Post #542808 Wed Dec 06 2017 8:21pm
nebc100
Thanks... That is what I thought, but just wanted opinions.
I will look at replacing the discs and pads even though they were supposedly done last year.
Post #542809 Wed Dec 06 2017 8:23pm
N60613
Bosnia Herzegovina
Nick, you may try "cleaning" your brakes. on the heavy cars like RR it is easy to post brake pads material deposit on the disks and it feels like warped disks. before you go changing the hardware tray this: bring car to ~140km and brake to ~40 km with increasing pressure on the pedal then accelerate and repeat 3-4 times. this should clean the disks. if this doesn't help you can always change rotors. Thumbs Up
Post #542983 Sat Dec 09 2017 7:34am
gogsy1956
Make sure you don't have any sticky calipers,, I had this symptom, I had to have the EPB completely overhauled and they found a sticky caliper while doing the work,, they managed to free it off and all has been fine since 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #543012 Sat Dec 09 2017 1:17pm
