![]() | Home > Technical > Another What battery thread. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I think that the cold spell has revealed that my battery is past it's best. It's a LR branded (Varta) YDG500130, but I cant see any date stamp so have no idea how old it is. It would appear to be OEM and a lead acid. If it's the original it's done well at 7yrs old, which is feasible going from my last D3.
Got you. The Amp/hour is higher, but the CCA is actually 50 less then, although the LR fitted says SAE and the Exide measures it in EN. Looks like I need to do some more research. Many thanks.
