Home > Maintenance & Modifications > EML light
Tome
2006 Range Rover Sport Supercharged Siberian Silver
EML light
Hello all, about every 2 days i get an EML light come on my s/c with the pcodes being
P0174 - system too lean bank 2
P0172 - system too lean bank 1
And somtimes this one aswel
P0420 - catalyst system efficiency below threshold bank 1
I have had a listen for air leaks with nothing obvious, clean the throttle body and ran some BG44K through the system.
Seams to drive normal with the light on. It never used to do it just the past couple of months or so. It was serviced with the plugs changed about 8000miles ago, not sure on the service schedule for plugs on these to be honest.
Any ideas???
Post #542100 Tue Nov 28 2017 8:29pm
geoffsnook
90000 miles for the plugs make sure the oil filler is secure and also the fuel tank cap as this can effect the system as i was getting them a lot whilst running on gas in mine so made sure they were tight and no more codes since may not be your issue but its a cheap starter to be getting on with Thumbs Up
Post #542139 Wed Nov 29 2017 6:45pm
Tome
Ahh intresting. I have no oil leak on it but will check the filter any way. Was the seal split on the cap then?
9000miles for plugs, there due again then!! Maby that might be a cause
Thanks for the reply i will get checking
Post #542153 Wed Nov 29 2017 8:28pm
Disco_Mikey
90,000 miles, not 9,000 Thumbs Up
Post #542155 Wed Nov 29 2017 8:35pm
Well if you get desperate.
Unplug the air meter.
Turn the ignition on fir 5 seconds.
Plug meter back in.
This should reset the learning
Post #542192 Wed Nov 29 2017 11:35pm
Tim in Scotland
Was there not an issue with high miles S/Cs of the MAF getting dirty/ an oil film on the sensor and cleaning it solved this problem? I am probably wrong on this but i’m Sure that there was a post either here or on FullFatRR about these codes and the cause was as above 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #542210 Thu Nov 30 2017 9:44am
I would suggest you don't clean the MAF sensor until you are sure / do research.
Very easy to break them.
Although these probably have the robust version.
Post #542231 Thu Nov 30 2017 12:11pm
