Home > General (L494) > L494 Fridge retrofit. is it possible.
thomas brown
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi Guys.
A friend of mine has bought a early 63 plate HSE dynamic which is very nice but he is gutted it doesn't have a fridge fitted !
As i found out when looking HSE specs don't include the fridge as standard anymore!!
How hard is it to fit the fridge in the cubby box on a L494 Sport? I guess the L494 Fridge is different to the earlier L405 ?
Any help would be great thanks.
Tom.
Post #541598 Wed Nov 22 2017 10:48am
360
United Kingdom 2011 Range Rover Sport SDV6 HSE Buckingham Blue
When my my17 was delivered without the fridge the dealer said it could not be retro fitted so because of that and a few other issues had to reorder a new car, they said the wire loom is different.
Post #541620 Wed Nov 22 2017 7:40pm
thomas brown
Hi 360.
Cheers for the reply. Oh that doesn't sound good !!
Surely all you need is a permanent 12v feed to make the fridge work or a ignition feed. I can't see it being a major to fit into position as long as you don't have to change all the centre console about as that would be a expensive part !!
If anybody has done it, it would be great to hear how it went.
Thanks.
Tom.
Post #541640 Thu Nov 23 2017 8:39am
econ
Is this the fridge in the middle compartment? I thought that thing was crap. Is it any good?
Post #541647 Thu Nov 23 2017 12:42pm
syl
The new MY18 comes with the option of a cooler (£240) or a refrigerator (£480). Is the difference just an ignition live feed or a permanent one? Smile
Post #541650 Thu Nov 23 2017 2:23pm
Canary
Depends on whether it's sit's in your car unused or you use it for what's intended for, no fridge would cool anything if only on for 15/30 minutes, but when on long journeys we use it to keep food and drinks cool until we reach our destination usually MK to Perth shire. MY18 SCV8 Satin flux silver
Gone:
MY19 SV VELAR AUTOBIOGRAPHY firenze red
MY18 SCV8 Yulong white- perfect 👍
MY16 SDV8 SANTORINI BLACK - perfect 👌
MY64 SCV8 DARK BLUE - nightmare car
MY64 SCV8 FIRENZE RED - loads of annoying issues
MY15 SDV6 FIRENZE RED - perfect 👌
MY12 SDV6 DISCO4 IPANEMA SAND - perfect 👌
MY09 TDV6 SPORT BLUE - lots of issues
Post #541670 Thu Nov 23 2017 5:55pm
thomas brown
Hi guys.
Yea mine is good i certainly wouldn't be without it.
All is needed is a ignition live surely.
Trying to remember now if mine comes on with the ignition or only with the engine running !
Post #541693 Thu Nov 23 2017 7:34pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
This is a clip of a post from Mark whose cooler was missed off his SVR back in 2015:
Quote:
The cooler can most definitely be retrofitted though the dealer may baulk at the parts cost. In my case, they stole one from a demo autobiography and for the SVR, a different power cable - which was available from LR parts ex-stock is required. Most important is that since the centre console has to come apart, they put someone on the job who is up to it. Cooler is worth having and I've found it useful in the recent warmer weather.
Post #541694 Thu Nov 23 2017 7:40pm
IRBails
Australia
To each their own. I have a mobile fridge I plug in the rear when I am travelling and this works fine. Also holds heaps so I am not limited to just a few items. Mind you the design of the centre console is pretty useless IMO and as a fridge would be very small. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #541704 Thu Nov 23 2017 9:11pm
thomas brown
Cheers for that Philmw.
Sounds like its possible even a landrover stealer can do it, so it can't be hard then !!!
All it needs is a power feed no matter what connection is used, least i know it can be done with the original centre console.
Thanks.
Tom.
Post #541708 Thu Nov 23 2017 9:25pm
The centre console cooler isn't a fridge and isn't intended to be. It's a cooler for a drink or a snack when driving. The cooler only works when the ignition is on. A fridge would be powered all the time, of course.
I use the cooler everyday for my lunchtime sandwiches and a drink. But I am in the vehicle for a few hours a day. 2012 SDV6 - it's missing a couple of cylinders
Post #541713 Thu Nov 23 2017 9:41pm
Black Bess
I had the cooler on my old L320. It was very useful. This new car doesn`t have one and since I only buy secondhand, beggars can`t be choosers. I suppose it does not motivate me enough to bother with a retrofit, but they are good things if you have one.
Post #541745 Fri Nov 24 2017 11:08am
abeachsoul
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
This is totally doable. I did it recently on my MY16 L494.
The connector was present but had no power so I guess wasn’t connected elsewhere in the harness. So I cut the connector off, isolates it and spliced the tail onto cigarette lighter socket.
Regarding the fitting of the actual coolbox itself, it fits mm perfect just slotting it in but you have to cut the existing cubby to allow for it. It’s a straightforward job using a multi-saw. You need to cut out the section that houses the media interface / accessory socket module. But I left little ears about 8mm each side to support the coolbox bezel for that same module.
Last thing to cut is the floor piece to the cubby as the cop box sit too high otherwise. Again simple but go REALLY easy when cutting through as the rear air ducts sit just beneath this and are VERY easily damaged. I learnt the hard way but easily repaired with duct tape.
Then you just connect it all up and slot it in.
I’ll post pics of when I did mine... '’16 RRS HSE 3.0 SDV6 - Carpathian Grey - 20" stealth alloys - Premium Merdian retrofit - TV and RSE retrofit - NavTool / Firestick
Post #604496 Sat Sep 12 2020 2:52pm
abeachsoul
Hers my install...
Post #604497 Sat Sep 12 2020 2:58pm
akalair
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I just finished doing this. Took me an hour tops. Great instructions above, but will just add some notes from my experience:
1. I only needed to cut as far as pic one in the pics above. Before making the final cut at the bottom, I placed a small metal plate between the ducts and where I was cutting along the line at the bottom. This ensured I didn't cut through the ducts. I didn't need to leave the 'little ears' in the corner for support.
2. Like I said, I didn't cut as far back as pic 4, but cut off the 4 locator pins at the bottom of the cooler box unit. This allowed it to sit down in the correct position. It is firmly in place and has no chance of coming out/moving.
3. The connection for the cooler box was already there and powered the unit straight away. So no need to splice into cig lighter wiring. I would suggest making sure a fuse is present (no. 21 10amp I think) before cutting the wiring for power.
abeachsoul -
What is the cover you have in the last pic? I would like to get one. I only have the one you do in the 2nd from last pic...
Summary - very easy install. Takes less than an hour and is a great upgrade which I'm sure I will use all the time. Just need to remember to turn off when not in use Smile!
Many thanks
Post #605910 Sat Oct 24 2020 2:31pm
