Home > Technical > Folding mirrors.
Cymruambyth
Wales
Folding mirrors.
Ok, I`ve sorted the mirrors to tilt when I reverse but.....is there anyway to stop the driver side one tilting? I`ve tried only selecting the passenger side on the knob but they both still tilt. Steve.
Post #541439 Mon Nov 20 2017 12:51pm
The dam things work their way further and further down on tilt so best to turn that function off !
Just manually dip the mirror when in reverse
Post #541441 Mon Nov 20 2017 12:59pm
Tim in Scotland
There is an easy way to fix the driver’s door mirror - set the reverse dip position for that mirror to be the same as when driving forward then it won’t seem to dip...... I have always set mine up that way 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #541454 Mon Nov 20 2017 2:36pm
Cymruambyth
Wales
Hey Tim....you mean when setting the memory settings yeah? Steve.
Post #541457 Mon Nov 20 2017 2:53pm
Tim in Scotland
Select R, adjust both mirrors to your preferred settings, back to P or D, no need to press the memory button, that is for going forwards with different drivers using the car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #541458 Mon Nov 20 2017 3:14pm
Cymruambyth
Wales
Ah yeah.....I got you Thumbs Up Cheers. Steve.
Post #541459 Mon Nov 20 2017 3:16pm
Cymruambyth
Wales
Nope, that doesn`t work Sad Any ideas? Steve.
Post #541768 Fri Nov 24 2017 4:20pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
When I bought my 2005 RRS, the passenger mirror dipped whenever I selected reverse (which I found annoying).
I cured it by resetting all 3 seat memory buttons with the mirrors in the normal positions. Worth a try.
Post #541778 Fri Nov 24 2017 5:49pm
LJRH
Whenever I park and turn the engine off then lock the car, my driver mirror spazes out and points whatever way it wants to. I have to reset it everytime I get back in the car. Noisy black one
Post #541818 Sat Nov 25 2017 11:58am
Cymruambyth
Wales
Thanks, I`ll give that a go. Steve.
Post #541826 Sat Nov 25 2017 1:38pm
What happens if you simply turn the dipping feature off completely in the settings menu on the stalk ?.
Post #541855 Sun Nov 26 2017 12:50am
Cymruambyth
Wales
I assume they won`t dip! Steve.
Post #541868 Sun Nov 26 2017 1:16pm
No they won't dip, that's the object of the on or off setting, so what are you trying to do make the n/s dip and o/s remain stationary?
Post #541871 Sun Nov 26 2017 1:39pm
Cymruambyth
Wales
Thumbs Up Steve.
Post #541877 Sun Nov 26 2017 2:11pm
