Home > General > Front door Seal
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Front door Seal
Drivers side does anyone know where to buy other than LR dealer?
Post #541217 Fri Nov 17 2017 11:47pm
GodivaNige
Replaced my drivers side inner recently, bought from Dan @ Duckworths for approx £55
Less than 1/2 an hour to fit
Post #541222 Sat Nov 18 2017 7:44am
scousefly
Is there
A how to anywhere? Is it easy enough like a push fit?
Post #541223 Sat Nov 18 2017 8:27am
GodivaNige
You need to lift the plastic kickplate at the base of the door opening, but you don't need to completely remove it. Just gently pull until the fasteners release to be able to extract the seal.
Then you can pull the seal from around the whole aperture.
Push fit the new seal with the aim to have the join under the kickplate. give it a good bang into place, a rubber mallet helps especially making sure it is seated in the corners. Trim off at the join with approx 3/4 inch overlap then force it to seat. I put a dab of vulcanising glue on the faces where the seal joins.
Tap the kickplate back in, stand back and admire your new door seal
Easy Thumbs Up
Post #541226 Sat Nov 18 2017 8:45am
That's strange, when I replaced mine it came from L/R already bonded together, in effect making it one piece.
Post #541227 Sat Nov 18 2017 8:52am
GodivaNige
Ah, OK, that might be so for later models. Mine was part number LR044024 for pre facelift RRS1 and it wasn't supplied already joined. It can be used in the front or rear door apertures, so effectively wouldn't be already joined as the two require different lengths.
Post #541228 Sat Nov 18 2017 8:54am
GodivaNige
Just remembered, the new part comes with the paracord inserted which you remove as you push the seal into place which effectively lifts the rubber lip over the internal trim
Post #541229 Sat Nov 18 2017 8:58am
Same part number for Facelift RRS1 variant, L/R probably saving themselves a few pence by not bonding them now. Laughing
Post #541230 Sat Nov 18 2017 9:02am
GodivaNige
Yes, I edited above to mention its the same part number now for the rear door aperture too, so you're right, LR combining the same part number and supplying without the join.
Post #541231 Sat Nov 18 2017 9:05am
Jaggs
I got one from duckworths a few months it also not jointed and needed trimming, I was expecting it to be a perfect fit was surprised I had to cut to fit Nanocom Evo
Post #541236 Sat Nov 18 2017 10:26am
