Home > Technical > cd loading |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Did you know there is a special sequence you have to follow to load CDs, its not like other cars I have had. It explains it in the manual, if you don't have one, I will look it up for you. |
Sat Nov 18 2017 10:39am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Press the CD button, then slot number you want the CD to store in, it will then tell you to insert disc. Of course this only applies if you have the multi-disc player.
Sat Nov 18 2017 11:08am |
Nige Member Since: 29 Oct 2017 Location: lancashire Posts: 82 |
its that long since i used it i forgot ,,SORTED BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 18 2017 11:24am |
