![]() | Home > Technical > Timed climate never works |
In my experience, if you're not doing very long journeys very regularly, the battery won't stay sufficiently charged. Battery management module will then not allow battery draining below a certain level by refusing to operate secondary features like timed climate so that the car can still be started.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Just to add and support to fkarim's thoughts, my understanding is that the remote activation overrides any default temperature settings. In other words the temperature consideration does not apply to remote activation.
2008 is different from 2012. The 08 one you can use the remote kit to fire the FBH at any temp.
The other thing is, is your fuel gauge always accurate or does it have the common wiring fault and shows empty occasionally? Bodsys Brake Bible
Willywilson1980 Member Since: 04 Oct 2015 Location: Chester Posts: 9 ![]() ![]() |
Thanks all for the advice and thoughts. I suspect probably is battery related as typically do lot of short journeys. But I’ve also tried after the cars been for long runs and I know (the new) battery will be chargerd. Also very hit and miss, sometimes working great after short journeys and not at all when you’d expect the battery to be well charged. Most common is that it activates but only runs for a few minutes.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Have had this prob before.
Thanks again all for comments. Checked the battery, it’s non land rover and capacity 900A / 12V / 100AH. Can’t seem to find details for what original Landrover is - does anyone know?
My understanding of hard reset is to remove both leads from the battery terminals and then touch the two leads together. CARE just for clarity, we are touching the diconnnected leads together, NOT shorting out the battery which would be a very dangerous thing to do.
