Home > Technical > Timed climate not available..... |
They can generate spurious messages sometimes. Its because the voltage is lower than it should be and is probably going through some checks outside of the normal order due to the voltage level.
Wed Jan 28 2015 1:52pm |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 |
What does the timed climate and remote heater actually do. Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
Wed Jan 28 2015 1:57pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Timed climate allows you to set the time you want the diesel fuel heater to switch on and warm the car up for you, if the outside temperature is below around 4 degrees.
Wed Jan 28 2015 3:11pm |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 |
Thanks for the reply. The car had a low battery when I bought it (from standing at the dealers) but it charged up fine on the run home and I've had no problems since. But I'll check the battery over the weekend to make sure all's well. As for enabling the TC, I might take you up on that but possibly in a couple of months time when I can get chance to get up your way (and build the post Christmas/new car funds again). Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey Previous: Discovery 3 2.7 TDV6 HSE in Zambezi Silver |
Wed Jan 28 2015 3:18pm |
no problem Ovey
Wed Jan 28 2015 4:24pm |
Somerset Bumpkin Member Since: 12 Dec 2012 Location: Swindon Posts: 74 |
I have a 59 plate MY10 and mine has always done this, both before and after I enabled the park heating feature. Ive had the car for 2 years and it's never let me down or struggled to start so I've just put it down to a software glitchand not the battery as the remote park Heat works a treat. |
Wed Jan 28 2015 5:46pm |
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 |
Can you enable a timer or remote for a 2007 RRS? |
Wed Jan 28 2015 6:24pm |
No ace, you need either a webasto 1533 timer or the remote kit from bell auto services. Bodsys Brake Bible
Wed Jan 28 2015 6:29pm |
Thanks for the info Bodsy . |
Wed Jan 28 2015 7:04pm |
For info I used the hack to get into the diagnostics on the touchscreen. With only the ignition (and rear reading lights, grrr) on the diagnostics showed the battery as 11.8V so I'm happy it's not a low battery. I think it might just be a glitch.
Wed Jan 28 2015 9:26pm |
Yes I can enable towing electrics. Bodsys Brake Bible
Wed Jan 28 2015 11:58pm |
gwak2002 Member Since: 16 Nov 2017 Location: London Posts: 2 |
Hi - just bought a 3.0 SDV6 HSE Dynamic and wondered whether the timed climate can be made available - happy to buy a remote but does it need anything on the hardware side? |
Thu Nov 16 2017 6:28pm |
Yes, needs enabling on the car for timed climate, the remote needs a receiver aerial and plipper (I have them for a great price btw.... ) Bodsys Brake Bible
Thu Nov 16 2017 6:59pm |
Thanks Bodsy - can you PM me costs - but i see you're in shropshire - you ever get down north london? |
Fri Nov 17 2017 10:18am |
