Home > In Car Electronics > Driver and passenger courtesy lights stopped working
Scrumpy
Hi, can anyone help please with my 2005 4.2L SC?
Not sure if I m looking for a fuse but wanted to ask others out there first.
I have a dash cam hard wired into the courtesy light console through a 5v step down converter and the dash cam and both the passenger side and driver's side courtesy lights have stopped working although the central courtesy light still works?
It was probably my own stupid fault as I had just bought a CTEK charger and it was connected whilst washing the car and I needed to move the car back 2 feet so started it (without disconnecting the CTEK) and moved it back.
I didn't notice immediately that the dash cam and lights had stopped working but it is a bit of a coincidence or could it be to do with pressure washing the car (the sunroof has leaked before and water got into courtesy light console).
It's worth checking the fuses but i don't have a manual to hand, does anybody know what it could be or which fuse to check?
Many thanks in advance. 2016 RRS SVR Estoril Blue
Post #540758 Mon Nov 13 2017 1:15pm
off the top of my head.....
If the rear roof lights don't work when the switch is pressed, you have blown fuse 1 or 2 behind the glovebox
Post #540784 Mon Nov 13 2017 7:43pm
Scrumpy
Thanks Andy, I will have a look at those.
It's strange because the central light works, but not the passenger or drivers lights either side of the central one. 2016 RRS SVR Estoril Blue
Post #540809 Tue Nov 14 2017 10:43am
It's
Fuse No.1
Red 10A
Post #540856 Tue Nov 14 2017 6:18pm
Scrumpy
Thanks Andy,
I'll check at the weekend when i have some daylight.
I'll also get a continuity tester as last time i pulled a fuse and put it back i blew the BCM and it cost me £££££!!!!! Embarassed
Also noticed that my 3 flash indicators have stopped working that i activated with the IID tool about a month ago but the clock on dash that i did the same time is still there.
Don't see how it can be related but again, bit of a coincidence.
Any thoughts??
Many thanks 2016 RRS SVR Estoril Blue
Post #540860 Tue Nov 14 2017 6:50pm
