Home > Wheels & Tyres > New RRS owner. need wheel advice
ODAK
Hello all
I am just about to take delivery of 06 RRS. It has 20 275/45/20 tyres and wheels but spare has 19 and apparentlyy will be ok since tyre a larger equation. 50?..but I am doubtful. will wind uo diff surely?
Also...
Will a LR008548 - 20 inch 9.5J 15 Spoke Alloy Wheel - Sparkle Silver Finish. fit with 2005/2006 sport? ion so will buy and put cheap spare on
1. is the 19 ok?
2. will the LR008548 - 20 inch 9.5J 15 Spoke Alloy Wheel - Sparkle Silver Finish. work on this generation of RRS?
Thanks
Post #540676 Sun Nov 12 2017 7:53pm
The 19 will be ok if it's 255/55/19 as that is very close to the 275/45/20. 255/50/19 is a bit small. It won't wind up a diff as such but it might annoy the stability control system enough to make it intervene at times.
Does the RRS you are buying have Dynamic Response? If not, check that it has the updated steering rack. The early RRS didn't come with large diameter (20 inch) rims. 2012 SDV6 - it's missing a couple of cylinders
Post #540688 Sun Nov 12 2017 10:35pm
ODAK
Thanks TDV8. I will check this out. mind you deposit paid and so its had belts done and new gearbox oil/filter pan. etc
so fingers and other parts crossed
Regards
ODAK
Post #540692 Sun Nov 12 2017 10:52pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi Pal just let you know having different wheel sizes on a single axel, not only is it illegal and can earn you 3 points , but should you be involved in an accident your insurance will be null and void! So please be very careful and also MOT Failure
S&F
Mani G MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
REAR 9 INCH TOUCH SCREEN HEADREST TV SCREENS, WIRELESS HEADRESTS, IN-CAR WIFI MIRROR BOX FOR WATCHING INTERNET TVIE BBC I-PLAYER ETC... FROM ANDROID, WINDOWS AND IOS PHONES ON THE GO ON ALL SCREENS
Post #540693 Sun Nov 12 2017 11:09pm
Johnski
Except in the case of the emergency spare wheel which is often a different size and also speed and distance limited for use. One of the legal quirks with wheel sizes. The rest of your statement is correct if used as normal wheel. John
Post #540695 Sun Nov 12 2017 11:15pm
Mani
Thumbs Up Bow down Bow down Bow down MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #540696 Sun Nov 12 2017 11:21pm
Re: New RRS owner. need wheel advice
ODAK wrote:
Hello all
Also...
1. is the 19 ok?
Thanks
A LR008548 wheel rim now a LR027544 will certainly fit a 06 plate car, and with a 275/45 x 20 tyre it will also fit up into the spare well O.K. with no problems.
Post #540699 Mon Nov 13 2017 12:56am
