Home > Maintenance & Modifications > Rear end vibration at high speeds and breaking |
Interpreting that literally - your tyres are underinflated. Try them at 36 psi using an accurate pressure gauge. If no improvement inspect the rear brakes including the EPB shoes and while you are in there check all the suspension components for wear. 2008 MY Java Black TDV8 HSE |
Sun Nov 12 2017 10:48am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Hi Paddi,
Sun Nov 12 2017 11:02am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Could be warped brake rotors. Could be wheels, tyres or rear diff. Don't know how long you have had the car? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Nov 12 2017 12:29pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Had it on mine brake callipers were seized.
Sun Nov 12 2017 12:47pm |
Hi BKHK,
Sun Nov 12 2017 4:34pm |
No they can't be actuated. The IID can put the EPB in service mode and has a facility to reset a jammed EPB (does not always work though) and to bleed the brakes. In addition of course it reads any brake related fault codes. The brakes can be overhauled and adjusted without using. IID tool- see the great 'Bodsy's brake bible' If you have one or more seized calipers they will be very hot after running so do a comparison by feeling the road wheels. Vibration could also be a buckled wheel and by the sound of it your low budget tyres and poorly balanced rims will not be helping matters. 2008 MY Java Black TDV8 HSE |
Sun Nov 12 2017 5:41pm |
They could be seized in the off ie not breaking. Wheels off to see if working.
Sun Nov 12 2017 7:29pm |
