![]() | Home > General > Best D3S bulbs ? |
My D3S are already very white and as far as im aware are the standard Bulbs that came with the car.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
Apparently they came out of the factory with 4300k bulbs which have a more yellow light than white so it sounds like yours might have been changed.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I fitted OSRAM Night Breaker Unlimited D3S bulbs to my 2010 TDV8 and the difference was substantial compared to the original factory OSRAM bulbs. I did a check of light output using a light meter at 25m and OSRAM's claim of +70% is not an exaggeration. I did the test with the passenger side headlamp using the original bulb and the drivers side using the Night Breaker Unlimited bulb.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
I buy from this place, and changed mine to 6000k from stock HIDs. Few years back, one of the HIDs that i bought from this shop for my Freelander 2 failed just before the 12 month, and the guy sent me a replacement the next day.
darrenparker222 Member Since: 01 Jun 2020 Location: Kent Posts: 1 ![]() ![]() |
Hey mates
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Philips or Osram would be ok. I think Osram were the OEM supplier. I put Osram Nightbreaker in D3S and H7 (for the main beam fill light) and both of the existing bulbs were standard Osram items. 2012 SDV6 - it's missing a couple of cylinders
