Home > Technical > Cam Sensor Removal
N19
Cam Sensor Removal
Hi
2006 2.7
Could anyone tell me the best way to remove the cam sensor please
Thanks for any advice
Post #540105 Sat Nov 04 2017 10:08am
from the top of the engine i think,
one 8mm bolt ?
try and leave the connector the last thing to disconnect if its doesn't want to unplug easily.
Post #540108 Sat Nov 04 2017 10:24am
N19
Alright Andy,
Thanks for replying,
Iv had 1 go at it I couldn't get to it, I removed egr pipe I was tempted to remove the end of the egr cooler looking part, I tried going in from passenger wheel, not alot of room either way
Post #540111 Sat Nov 04 2017 10:32am
Disco_Mikey
I believe the whole EGR valve needs removing to get the sensor out...
Post #540113 Sat Nov 04 2017 11:01am
N19
Hi Mikey
Thanks I will try it that way
Post #540114 Sat Nov 04 2017 11:05am
Disco_Mikey
Any particular reason why you are replacing it? In 12 years, I have never seen a faulty one...
Post #540117 Sat Nov 04 2017 12:24pm
N19
Hi Mikey
it hasnt started a few morning until the 3rd or 4th try
This code every time code P0341
Post #540118 Sat Nov 04 2017 12:30pm
Disco_Mikey
First time for everything I guess, but every time I have seen that code, the timing has been out...
Post #540119 Sat Nov 04 2017 12:44pm
N19
ok I will check that aswell I will let you know
Thanks
Post #540120 Sat Nov 04 2017 12:47pm
