Home > Technical > Lost communication with suspension control module B
shortty
Hi Guys,
Got a peculiar problem with a MY10 RRS. Code scan error U0139 Lost communication with suspension control module B. I can raise and lower the car as normal and it does all the right things like bring the height back to NORMAL is driven too fast in extended mode or access mode. I can calibrate the ride height (it was out by 15mm on NSR)
If I try to access the Active Damping Control module, my Verus Pro says it can't communicate with it.
However, if I try using one of the suspension programs like SNOW, I get the message SPECIAL PROGRAMS NOT AVAILABLE. No other warning lights or indications that anything is wrong.
I have to say that when driving, the car feels very light and slightly wobbly.
The only other thing is that the air pumps seems to take longer than normal to pump up the pressure, but must be working as I can raise/lower the car.
Post #539705 Mon Oct 30 2017 3:03pm
