Home > Off Roading & Green Laning > Winch Cherry
Pufftmw
Winch Cherry
Managed to use my winch in anger for the first time time yesterday. I have some land in Wales, which I am clearing as its completely overgrown. To do this, I have a small 4wd tractor & a flail mower etc. Tractor is normally a totally go anywhere machine but yesterday I was in the lower part which is shady and a bit boggy in places as the ditches have filled in. Needless to say, it got stuck - well and truly. I tried rocks, I tried branches, I dug out in front and underneath and it just kept sinking. The flail on the back is heavy, which is probably why it didn't come out.
Anyway, time for the RRS I decided, so I had to drive it across this field of grass higher than the bonnet - that horrible thick grass that just sticks up - then as close to the boggy bit as I dared. Was a bit nervous about getting that stuck as well. Fortunately enough length to get to the tractor, linked it all up, set the tractor driving (spinning) then winched until the tractor was making headway on its own again. Phew!
If the tractor gets stuck again, not going to fanny about trying to dig it out, will just go and get the RRS.
Post #529868 Sun Jul 09 2017 10:42am
Tim in Scotland
Might be worth getting a ground anchor for the RRS as well in that case, especially if you have no really beefy trees that you can put a tree strop around to stop the RRS from being pulled toward the bogged in tractor........... you utilise the tow bar for both the tree strop and the ground anchor. Or a set of beefy sand ladders for the tractor!
After being dragged into bogged in Defenders several times when winching them I bought what seemed to me to be a huge plough style ground anchor, since buying it I've never needed to use it ... Embarassed It seemed huge as I also use anchors on 35-60ft sail boats and when you see what is recommended for a 12t sailing boat it looks tiny compared to what is recommended as a ground for a 2.7t Defender! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #529871 Sun Jul 09 2017 11:03am
Pufftmw
Thanks Tim, will think about that. I do (currently) have masses of trees (overgrown hedge) around to which to do that with and the tractor is only 880kg, so hopefully tractor won't get that stuck!
Didn't need the winch today and more confident about dragging large plant trailer around the field after I realised I'd maneuvered it down and up the grassy hill with the brake on Rolling Eyes
Post #529908 Sun Jul 09 2017 8:36pm
El Matador
United States
Nice! What winch / winch bumper combo are you using? I'm looking at one myself
Post #532046 Fri Aug 04 2017 8:53pm
Pufftmw
Well, had to winch a 7.5 tonne flatbed out the mud this morning! I needed some gravel at the entrance to a field as its getting a bit boggy and had some delivered. Only problem was that the truck got itself stuck after it had unloaded (guess I need some gravel eh?), so once again, winch to the rescue!
At least its getting some use Smile
El Mat - its the Land Rover fitment with a Warn 9.5hp winch. I need to change the steel cable over to synthetic though
Post #539413 Fri Oct 27 2017 9:29am
Buckster
Just be careful with a wire and the rating for heavy stuff mate because when it goes it goes in a spectacular fashion! Seen it happen at a pay and play day and it wasn’t pretty!! Hope you use a cover damper on the wire Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #539415 Fri Oct 27 2017 9:33am
Pufftmw
Thank you Thumbs Up Hence the need to replace with synthetic! On my (extensive) shopping list...
Post #539417 Fri Oct 27 2017 9:41am
Tim in Scotland
Suggest that you periodically (every 5-6 months even with no use) run out the wire - wear riggers gloves while doing it in case of broken strands - examine it for surface corrosion and open up the wire lays and check that there is no internal dryness or corrosion. The legal time to condemn any lifting wire is when you have 10% of the strands in any 8 diameters length broken. Lubrication of the wire with a good quality wire lube or fish oil (very good lube but you will stink of rotten fish for weeks afterward!), never use grease though as it doesn’t penetrate to the Centre of the wire and can trap dampness in the strands.
Synthetic ropes aren’t without their issues too though - they need to be washed to remove any grit which will fray the strands after use in sand/ mud and they degrade in u.v. and sunlight so should be kept covered when not being used. Size for size though they are stronger than wire and MUCH lighter. If you have used your winch with a wire on it then you will have to replace the fair lead with a new one designed for use with synthetic rope and also because any channels cut in the fair lead by a wire rope will destroy a synthetic rope in seconds as the edges of any groves made by the wire act like knives on a synthetic rope. The biggest positive for a synthetic winch rope though is safety - when they break they don’t whiplash like a wire does. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #539419 Fri Oct 27 2017 9:53am
