Home > Technical > Test fuel burn heater? |
NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36 |
I managed to get it working via the IID tool, but only with the engine on. Some warm fumes out of the small exhaust, no smoke.
Sun Oct 22 2017 7:31am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 |
with an iid you can do a test run which takes a minute or two.
Sun Oct 22 2017 11:23am |
On timed climate (or remote climate if fitted) it DOES use the temperature to decide if the Fbh fires.
Tue Oct 24 2017 7:49am |
Hi. Bodsy,
Wed Oct 25 2017 8:59am |
millsy123 Member Since: 02 Dec 2017 Location: bham Posts: 4 |
my fbh runs even when dash temperature shows centre position ie up to temp...my fuel consumption as gone from 24/25 to 17/18 mpg ..can i pull a fuse that stops it working when not needed ie long trip so i can get some economy..i have read somwhere that poor thermostat performance can be culprit ..but surely if gauge says up to normal temp the fbh should click off...any help appreciated happy new year..
Wed Jan 03 2018 4:47pm |
the whole point of it, should be that it improves economy.
Wed Jan 03 2018 6:05pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
That’s right, there are two heating modes. 2.8kw and 5.0kw
Wed Jan 03 2018 6:26pm |
I thought they only fired up around 4/5°C |
Wed Jan 03 2018 6:49pm |
I’m quoting from the service manual, it says 9 C....
Wed Jan 03 2018 6:52pm |
Wed Jan 03 2018 8:38pm |
hello guys thanks for input..i cant remember where i read about thermostat ..it said that if thermostat was wide open would effect fbh ..i just didnt fancy changing it at this time of year ..but as you say your mpg didnt drop so badly i must have some problem..i have long trip monday to felixstowe must be three hundred miles round trip ill see if it improves with a run..ive only been local lately..i suppose its all about where the fbh takes its temperature control from..i though logically be on same route as temp gauge but im no sparky..my rrs is se so i dont have on dash diagnostics ..in retrospect its a mistake to not have i thought it was just sat nav i would not have..duhh If i remove fuse after cool down period will it be ok to do that..i could then test return mpg if it fails to clear..will pulling fuse reset fbh ..it may be all it needs just for your info i have no lights or warnings on my dash ..its a 2.7 diesel se 2006 vintage with 91k on clock runs great |
Wed Jan 03 2018 10:36pm |
Don't think you are missing any HSE features.
Wed Jan 03 2018 10:41pm |
