Home > Technical > power steering problem
steve.rrs
im finding that after a few hours use the power steering starts to get a bit stiffer, would changing the power steering fluid help
Post #538569 Wed Oct 18 2017 6:35am
No.
Post #538592 Wed Oct 18 2017 12:11pm
there a post on D3 where by the steering column is lubricated at the side of the engine.
This may cause a short term fix and pin point the problem so a part (joint?) can be replaced,
https://www.disco3.co.uk/forum/topic164744.html
Not sure its an exact match with your issue
Post #538622 Wed Oct 18 2017 5:22pm
shepp
I had a similar issue on my last rrs. Eventually it got worse, then resulted in excess play.
It turned out to be the universal joint. They cost around £50 and isn't to major to swap. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #538627 Wed Oct 18 2017 6:08pm
steve.rrs
i did a lot of driving today, it seems to start getting a bit stiff after a few hours, when i turned the engine of for about an hour it was fine till about a couple of hours driving it started to give stiff again
Post #538659 Wed Oct 18 2017 8:02pm
Must be the heat from the engine near the joint.
Post #538662 Wed Oct 18 2017 9:01pm
