Home > Faults & Fixes > Normal suspension height only error
madtoro
United States
I am getting a "Normal suspension height only" error on the dash popping up anything from 30 secs to 5 mins after starting. I can move it up and down fine before that, no dropping or air leaks and I have replaced the Air dryer on the compressor (which is lovely and quiet). No fault codes on my reader either.
Anyone had similar or any ideas?
Oh and its a 2010 RRS V8
Post #538455 Mon Oct 16 2017 4:17pm
shepp
hello
posibility of an internal leak on the compressor, the springs on the valves can become weak.
check out the below
http://www.rrsport.co.uk/gallery/albums/us...rogram.pdf MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #538545 Tue Oct 17 2017 7:28pm
madtoro
United States
Thats good info, thanks. I'll take a closer look at that and see what I find
Post #538549 Tue Oct 17 2017 8:02pm
madtoro
United States
Just to close this off -
I replaced the dryer cannister and the fault remained (although the old one was wrecked inside, so was replacement was required anyway), although slightly less frequently. I cut off 1/2" off the tubes and re inserted them into the cannister.
Problem solved. It was a tiny air leak due to worn pipe into the dryer connections. Been running excellent for a couple of months now.
Post #543186 Mon Dec 11 2017 5:33pm
