Home > General > Winter prep with new Ctek mxs10
shepp
Hello all
As winter approaches, I am sure many of you will be using the pre heat function. Below is a couple of links to get a reasonable price Ctek and adaptors
Ctek mxs10 £105.98
http://www.justcarbatteries.co.uk/ctek-mxs...arger.html
2.5 meter ctek comfort extension £11.99
https://www.amazon.co.uk/gp/aw/d/B00ADIHUV...&psc=1
Tow bar adaptor ( From rrs site) my option cost approx £27
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
The above eliminates the hastle of lifting the bonnet.only takes 1 minute to attach and detach charger.
For a total of £150, it's well worth it
Very Happy Very Happy MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #538361 Sun Oct 15 2017 6:46pm
Buckster
I use the tow electrics via a forum plug on the CTek, top bit of kit 👍 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #538363 Sun Oct 15 2017 6:51pm
shepp
It is an excellent bit of kit and so easy to use. I would have put one together myself, but as I am getting fatter, balder and lazier. With two children under 5. It's nice to get it delivered complete through the post. Very Happy MY12 RRS HSE
Gone 90
Gone s2000
Post #538365 Sun Oct 15 2017 6:59pm
DrRob
Snap! Great bit of kit that tow electrics adaptor. Visitor from fullfatrr.com
Post #538366 Sun Oct 15 2017 7:10pm
I find driving 100-150 miles per day keeps the battery topped up and the FBH doesn't do for the battery even when used everyday. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #538368 Sun Oct 15 2017 7:18pm
I'm sure you would get the same benefit for £65 with a 5 amp version
Post #538371 Sun Oct 15 2017 7:33pm
LTFR
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Siberian Silver
Got my 5 amp ctek and 2,5m extension delivered today after reading an earlier thread on the subject which is spooky. Just need to check I've got a permanent live feed on the 13 pin socket before opting for the adaptor, its got to be easier than popping the bonnet and attaching directly to the battery.
Only hope the missus doesn't forget that its attached and drives off without disconnecting it Big Cry 13MY HSE BLACK SDV6 in Siberian Silver
Post #538375 Sun Oct 15 2017 7:47pm
shepp
5amp version is fine, 10amp is quicker, I was going to get the 25amp version but was not suitable for using the tow bar electrics.
LTFR mine is the 13 pin and works fine. Part of the 13plug configuration is permanent live and earth, so you should be fine. Also the kit comes with a laminated warning sign saying it is on charge. Stick it in front of the dials or remove the clip on the comfort extension so it unplugs if driven away MY12 RRS HSE
Gone 90
Gone s2000
Post #538378 Sun Oct 15 2017 8:46pm
shepp
A Nissan Micra will also get me from a to b
Whistle MY12 RRS HSE
Gone 90
Gone s2000
Post #538379 Sun Oct 15 2017 8:48pm
Depends what you are after.
If you are organised and what maintance charging then 5A or less is fine.
If you have let the battery go flat, then a 10 will recharge it quicker.
Post #538386 Sun Oct 15 2017 9:50pm
