Home > Maintenance & Modifications > Leaky Sunroof - Air gap -
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
Hi all,
I have a leaky sunroof, it doesn't seem to be sealing properly around the back. With it fully closed I can actually see the sky through a tiny gap. Also it sounds windy on motorway, so annoying.
I have tried the reset trick with holding the button down etc, but it made no difference.
Anyway, I have bought a new seal, LR023393 - but I have no idea how to fit it. Do I need to take the headliner off? I have search internet and YouTube and no luck.
Thanks, John 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #538260 Sat Oct 14 2017 10:57am
geoffsnook
Interested to know how you get on as i can see light through mine and water drips in but apparently that's normal Rolling with laughter
Post #538275 Sat Oct 14 2017 5:15pm
Cymruambyth
Wales
Laughing Steve.
Post #538281 Sat Oct 14 2017 7:55pm
Tim in Scotland
You local dealer will probably tell you it is a ”characteristic” of the car now that one person has raised it........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #538292 Sun Oct 15 2017 2:05am
Re: Leaky Sunroof - Air gap -
Citizen55 wrote:
Hi all,
Thanks, John
You do not need to remove the headlining, the seal locates in a groove/recess in the actual sunroof panel which you will not see until you remove the old seal. Tilt the Sunroof panel and remove seal from rear of panel and part way down the sides, then open sunroof part way and remove rest of seal. To refit close and tilt panel, start in centre of panel on rear edge and work seal into locating groove, basically refit in just same way as removed old seal starting at rear working towards front. Make sure you refit the seal in the correct orientation, make a note which way round the old one is before removing it. You might also need something to push seal into the groove like some sort of plastic tool that will not damage the seal.
Post #538294 Sun Oct 15 2017 5:06am
