![]() | Home > Maintenance & Modifications > Rear tailgate upgrade. |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
I should be doing one again very shortly for a forum member so I'll do a write up. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
You won't need to remove headlining, pull off tailgate seal and the lining will flex enough to undo the hinge retaining nuts, there are a couple off plastic clips in the centre of the headlining close to the edge of the lining, which if you just release them it allows lining to flex more. I didn't think anybody had actually got the electrics for the power operated rams working yet.
You can order the one piece tailgate 2012-13 facelift model through any LR parts supplier.
John, judging by the jeno's original post I think he already has the tailgate. |
Thanks Col. my bad |
No problem Buddy, how's the recovery going, well I hope?. |
Slowly but surely mate, thanks, hope to be able to drive again soon.
peter jensen Member Since: 08 Oct 2011 Location: New South Wales Posts: 4 ![]() ![]() ![]() |
Thank you Col and Johnski for a quick reply. I will have the 2012 tailgate in a couple of days it is just clearing Customs at the present time. It is a complete unit from a breakers in the UK. I am fortunate to have two good mates one a panel beater the other a spray painter who assist with fitting and paint.
Peter, if you PM me a email address I will send you some wiring diagrams which might help your electrician if it is of any use to you.
