Home > Faults & Fixes > Issues |
I would message Bodsy,,or one of the tech guys on here they will probably be able to help
Sat Sep 16 2017 2:50pm |
rangeroverloon Member Since: 20 Aug 2017 Location: leatherhead Posts: 9 |
Hi thanks for that I new to this site don't really know anyone but I'm from Surrey so if anyone could help that would be great and much appreciated.
Sat Sep 16 2017 3:02pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Here you go:
Sat Sep 16 2017 3:36pm |
The usual reason for that behaviour is that someone has changed the ride height to be lower. If the ride height is changed by say 10 mm then all ride heights (access, standard and offroad) are reduced by the same amount. If ride height reduced by more than 15mm then it is possible for the access height to be so low it hits the bump stops and the car thinks it is grounded and goes into extended mode to clear the obstacle it thinks is there.
Sat Sep 16 2017 5:05pm |
Aussie2012rrs Member Since: 19 Sep 2017 Location: Nsw Posts: 1 |
Have you replaced the pump?
Tue Oct 10 2017 7:26am |
