Home > In Car Electronics > Samsung s8 via I pod connection
tinybum
Hi guys I own a 2010 range rover sport s/c and I am trying find out if it's possible to connect my Samsung s8 via the iPod connector so I can use Spotify but I seem to be having trouble finding the any lead and connectors that work any advice would be appreciated
Post #537844 Mon Oct 09 2017 12:12pm
Paddi
The Samsung S8 has a headphone jack? (think so)
So you could use a lead with a 3.5mm jack plug on either end to connect to the aux jack socket at the rear of the centre console? Music volume may be a bit low however.
OR you could buy a cheap Bluetooth receiver and connect it to the aux and the power socket at the rear. I have one of these:
https://www.amazon.co.uk/Bluetooth-Receive...&psc=1
Works pretty well (better quality than the jack to jack solution) and doesn't interfere with the built in Bluetooth for phone calls. 2008 MY Java Black TDV8 HSE
Post #537856 Mon Oct 09 2017 3:13pm
tinybum
Thanks I'll give it a try
Post #537857 Mon Oct 09 2017 3:18pm
