![]() | Home > Maintenance & Modifications > MOT advisory - might need to get the wire brushes out |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Could be the pipes that run through the wheel arch or any of the pipes running under the driver's side cill. Time to jack it up and have a little peek. 2012 SDV6 - it's missing a couple of cylinders
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Assuming you've just has it tested, why not ask the tester while it's still fresh in his memory? I'm sure he or she will be happy to talk to you about it. |
MOT was a while back. Been a lazy |
