![]() | Home > Off Topic - Other Cars > Underwhelmed by the Velar...... |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
You forgot to mention it actually drives better than a RRS too |
Reedy Member Since: 12 Jun 2017 Location: Cumbria Posts: 5 ![]() |
You might be right RRSman, the fuel economy is undoubtably better but that's understandable being quite a bit lighter.
For me the MY18 RRS order depends on what is eventually updated and the price tag they put on it...I can see them becoming pretty expensive when spec'd high!
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
Isn't hi-speccing of cars the big mistake? I was told years ago to keep to a basic spec and that this would dramaticaly reduce the overall ownership cost. Afterall most of the extras are a waste of money, eg, head-up display, several hundred pounds to see the speedo reflected in the windscreen |
Can't argue with your analogy timhum wise words, but the heads up display is probably the future. |
You're right, most people don't need low range and other off-road gizmos but Dynamic mode is something everyone would enjoy as it transforms the drive IMHO. For that reason, HSE Dynamic was the minimum RRS spec I considered. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
I was of the exact same thinking when buying a car outright for cash. I have now joined the PCP game (after a lot of convincing from friends etc, putting the £80k elsewhere rather than in a car blah blah etc) and it works differently as the higher spec your car the less you pay per month. When I bought the Velar I got various PCP quotes on different trim levels and as the payment on the First Edition (which is FULLY loaded) was only £34 a month more than a much lesser car with less than half the options it made sense for me to go for this - being a ltd edition run it should also hold value more than the lesser spec cars. |
I don't quite get that. Using the RR configurator and comparing a RRS 3.0 HSE v 3.0Autobiography with a deposit of £5k and mileage of 12k p.a. over 37 months the monthly payment on the HSE is £853.72 and the AB is £1137.00 so £283 more per month. Perhaps the Velar works out differently?
Indeed - it all depends on the residual values also known as the GFV of the car after 37 months - at the moment the GFVs are not too good on the RRS as compared to the Velar as it is a newer car.
I've just run the numbers on the LR website, HSE £392.68 per month and AB £855.13 per month. The total price for the AB including interest charges is £27k more than the HSE. GFV on the HSE is £36k and the AB £44k.
These figures don't stack up |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
What makes the higher models much more affordable is if you start adding some extras to the lower models (which are standard on the higher models). These aren't reflected in the GMV.
Good point syl and in some way backs up my original comment, don't waste money on high spec cars. It will still be just as enjoyable.
That's a rather subjective comment Tim - a car with plenty of toys is always more fun than one without IMHO. I'm loving having pretty much every available option on hand for my First Edition Velar - makes the ownership experience brilliant |
