![]() | Home > Maintenance & Modifications > TDV6 and SDV6?!? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
it is a well-documented issue on the T/SDV6, more on the D3/D4 than on the RRS.
I have a 2011 3litre TDV6 with a proper gear lever and a 6 speed box plus a 2 piece tailgate.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
yes 252 versus 245 HP |
If you have the VIN number of said vehicle, you can go to LR TOPIx site and then not only will you get type of engine, gearbox, trim etc, it also gives a complete build sheet of everything fitted to car as standard or extra options, very useful for checking what car you are looking at when purchasing, and will give a true list of options fitted etc, rather than pre filled forms for model spec, which are often listed incorrectly by sellers and dealerships. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
smckeown Member Since: 31 Aug 2013 Location: West Sussex Posts: 27 ![]() ![]() ![]() |
I have a 2011 (2012my) with the 8 speed rotary and 3.0 tdv6 pushing out 211 ps. It was meant for commercials and is a detuned sdv6 basically |
Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 208 ![]() ![]() ![]() |
Amazing!!!! Never knew this existed, have registered and will get VIN tomorrow on viewing and check it out for spec etc. Thank you kind sir Si |
No problem, glad to help.
