Home > Faults & Fixes > 2007 range rover sport air suspension compressor location
rostan242@gmail.com
needs help finding the location of air suspension compressor rrs 2007 3.6, It is probably damaged(only normal high), it wants to regenerate it.
There are full movies on google but they are all up to disco 3, i found workshop manual but is to l322
Can someone share the information where I find compressor
thank you
Post #536423 Mon Sep 25 2017 9:55pm
Passengers side, bolted to chassis under rear door and covered by plastic cover.
Post #536431 Tue Sep 26 2017 12:39am
Tyrefitter
☝️ as Col says,,& it's a easy job to change.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #536432 Tue Sep 26 2017 1:20am
rostan242@gmail.com
thanks guys for a quick and specific answer
I just hope it can be repaired
Thanks
Post #536433 Tue Sep 26 2017 3:58am
garrycol
Australia
Re: 2007 range rover sport air suspension compressor locatio
Is in exactly the same spot as the D3.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #536434 Tue Sep 26 2017 3:58am
rostan242@gmail.com
As a colleague col wrote, I found pump thanks
By numbers it should be a hitachi pump
now I would need information when i lift the car pump should run all the time,My work until the error, but the car does not drop
And why only two tubes with air come out of the pump,Is it somewhere then divided into all the wheels.
Post #536479 Tue Sep 26 2017 4:33pm
