Home > General > head light problem rr sport |
raysheppard1954 Member Since: 21 Sep 2017 Location: birmingham Posts: 10 |
hi , Ive just brought a range rover sport tdv8 HSE 57 plate ,the n/s headlight is damaged it needs replacing ,my local garage told me that it will need to be programed ,is that right .i was hoping i could fit a unit from eBay any help thanks ,ray. |
Thu Sep 21 2017 1:01pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Not heard that one before - its plug and play. |
Thu Sep 21 2017 2:02pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I'm with Puff on this one. Very easy replacement but bloody expensive. Labour time about 5 minutes. Robin
Thu Sep 21 2017 4:11pm |
What is vote for? I have same line twice "Range Rover Sport". John
Thu Sep 21 2017 8:36pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Doesn't need programming. Probably just trying to get you to buy from them at silly money. 2012 SDV6 - it's missing a couple of cylinders
Thu Sep 21 2017 8:41pm |
thank you all for your replies much appreciated ,cheers ray. |
Fri Sep 22 2017 5:35am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
As others have said just plug and play, if it's an original headlamp and the white and yellow label on top is still legible it will have the part number on it. Make's it easier to get like for like.
Fri Sep 22 2017 5:50am |
