Home > Technical > Lumpy Steering
Eaters
Lumpy Steering
My RRS recently went into the local garage for replacement of the offside front lower wishbone (near one was done about 6 months ago). Of course part of the process meant full 4 wheel alignment which has been done.
Upon picking it up I notice that I now have a very lumpy feel to the steering. As you turn the wheel you feel a bit of resistance at certain points as if its resisting the turn. It feels the same whether you are turning left or right. Rather than a smooth movement as you increase the turn of the wheel, you get this lumpy feel where there is more resistance - then it s easy, then as you continue to turn the wheel, you feel another "lump". It occurs after about 15 degrees of turn, and again after a further 10 degrees or so, so that in turning the wheel through 90 degrees, you will get about 3 "lumps" where there is greater resistance to the turn. Worse still, when returning the wheel to the straight ahead position, it appears to get stuck at the lumps and rather than it spinning freely back to straight ahead, I have to force it back because of the resistance. If I don't the car would continue to turn in a circle.
I took it back in to the garage for the alignment to be checked again, and they say its fine but that I have a seized suspension bush or something???? Sorry, didn't get which one. So its going back in on Monday for further investigation
My question is, has anyone else experienced anything similar of has any ideas what it might be? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #535425 Fri Sep 15 2017 6:55am
Disco_Mikey
Lower steering column Uj Thumbs Up
Post #535433 Fri Sep 15 2017 7:33am
Eaters
Cheers Mikey. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #535437 Fri Sep 15 2017 7:36am
Eaters
I'm sure that you are 100% confident in your diagnosis Mikey, but its always nice to have confirmation. New lower steering u/j fitted today! Steering now sweet as a nut. Thumbs Up Thumbs Up Thumbs Up Bow down Robin
Gone:
MGZTT 190 2.5
Post #535901 Tue Sep 19 2017 5:10pm
